Which is a better four-wheeler for trail riding and drag racing 350 raptor or 400ex?
  • 3 months later...
The honda 400EX is geard more for top end not so u will out run the scrapter 350.As far as trail riding goes the scrapter is less heavy front end wise so this will make hill climbing more of a challange . Also the HONDA will have more ponies so stick with it. If u want a pure drag atv get a banshee trust me, i smoke moifided 400 and 450's all day! with no problem. so have fun shopping.
  • 4 months later...
  • 6 months later...
warrior/raptors hav very heavy front ends, thats y they suck for wheelies, 400ex has a very light front end
Both are decent trail machines, but I would favor the Honda of those two. Neither of those would be much of a drag racer. If you want to drag race, and don't have alot of money to spend, buy a two stroke. They are easier and cheaper to modify. An '87 or newer 250 Quadracer would be a good, inexpensive option, and they are good trail riders and would smoke either of the EX or the Raptor in a drag.
This is a very old post but I HAD to comment on this statement. This guys is so wrong on his info. The 400EX is not geared for top end. That is why it is the slowest 400. The acceleration on them is great. And the whole front end thing has already been mentioned.
Any mod that has power in here, please put it in the correct spot!
    • By justent_88
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
